             Menu command
             Description
             Location of the data bar fields
             Use floating data bar
             The data bar floats with the cursor in the drawing area
             Use floating data bar only when tab key is pressed
             The data bar floats with the cursor only when the Tab key is pressed; otherwise the bar does not display
             Do not use floating data bar - show data bar fields on fixed data bar
             The data bar displays on the top left side of the window, at the top of the Tool bar
             Activation of the data bar
             Allow numeric keypad entry for instant data bar activation
             When the floating data bar is displayed, enter numbers on the keyboard or numeric keypad to activate the first field
             Do not allow numeric keypad entry for instant data bar activation
             When the floating data bar is displayed, enter numbers on the keyboard only to activate the first field
             Do not allow instant data bar activation
             When the floating data bar is displayed, press the Tab key to activate the first field
             Field display on the data bar
             Show only primary fields on data bar
             Show only the primary data fields (for example, L and A for circles)
             Show primary and secondary fields on data bar
             Show all fields except the cursor location fields (X and Y)
             Show primary, secondary, and cursor location fields on data bar
             Show all fields
             Field cycling options
             Auto cycle to non-displayed fields when tabbing past last field
             When some of the data fields are hidden, press the Tab key in the last visible field to make the non-displayed fields become visible
             Do not auto cycle to non-displayed fields when tabbing past last field
             When some of the data fields are hidden, press the Tab key in the last visible field to return to the first field
             Location of the floating data bar
             Show floating data bar below SmartCursor cues
             When the floating data bar is enabled, displays the data bar below the SmartCursor cues (below the cursor)
             Show floating data bar above SmartCursor cues
             When the floating data bar is enabled, displays the data bar above the SmartCursor cues (above the cursor)
             Data bar activation on datum creation
             Show floating data bar after datum creation
             When the floating data bar is enabled, displays the data bar automatically after a datum is set
             Do not show floating data bar after datum creation
             The floating data bar does not automatically display after a datum is set. Press the Tab key to display the floating data bar.
             Display of the Exit Group button
             Use large exit group button
             When a group is being edited, show a large button with the label Exit Group in the upper right corner of the drawing area
             Use small exit group button
             When a group is being edited, show a small button with an arrow icon in the upper right corner of the drawing area
             Exit group options
             <Esc><Esc> exits group
             When a group is being edited, pressing the Escape key twice exits the editing window
             <Esc><Esc> does not exit group
             When a group is being edited, pressing the Escape key twice does not exit the editing window
